nickstanton
Apr 28, 2018Tutor
Hard Drive Support
does anyone have a list of supported hard drives? a cant get my WD Passport to work at all...
i would like to eventually set up 2 drives. one for media that i can access through itunes and my r...
Danny80916
Apr 28, 2018Luminary
Hey did you go to settings>>>>usb storage >>>>usb settings >>> approved devices to try to add yours I dont have a hard drive on mine yet I am going to give it a shot right now when i plugged in my WD 2tb it detected it.
- Netduma-FraserApr 29, 2018NetDuma PartnerI don't know a list of supported HD's but try the above advice and let us know
- nickstantonApr 29, 2018Tutor
i had dried that several times :( but after being on the phone with support for about an hour we figured out my 2TB hard drive is just glitchy and messed (i think its time for it to be replaced) we got my 4TB drive working decently well though
- Netduma-FraserApr 29, 2018NetDuma PartnerGreat to hear you found the cause and a different HD worked. Thanks for the update Nick!
