nickstanton
Apr 28, 2018Tutor
Hard Drive Support
does anyone have a list of supported hard drives? a cant get my WD Passport to work at all...
i would like to eventually set up 2 drives. one for media that i can access through itunes and my r...
Netduma-Fraser
Apr 29, 2018NetDuma Partner
I don't know a list of supported HD's but try the above advice and let us know
nickstanton
Apr 29, 2018Tutor
i had dried that several times :( but after being on the phone with support for about an hour we figured out my 2TB hard drive is just glitchy and messed (i think its time for it to be replaced) we got my 4TB drive working decently well though
- Netduma-FraserApr 29, 2018NetDuma PartnerGreat to hear you found the cause and a different HD worked. Thanks for the update Nick!
