AlphaIOmega
Mar 11, 2020Aspirant
Hard reset on Netgear R8000
So my R7000 died last night. Press F to pay respects. I went out to a second hand store and found an X6 R8000 router, but the last user changed the admin password, and Im locked out of changing an...
Mar 12, 2020Guru - Experienced User
"F"
Did you push and hold while powered on?
Have you tried a 30/30/30 reset? push and hold reset while powered on for 30 seconds, power it down for 30 seconds while still holding reset, then power it back on for 30 seconds while still holding reset?
Potentially you could also try forcing new firmware to it via tftp.
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
- AlphaIOmegaMar 12, 2020Aspirant
I have tried the 30/30/30 method, and TFTP is not possible as the router does not get assigned an IP address :(
- plemansMar 12, 2020Guru - Experienced User
AlphaIOmega wrote:I have tried the 30/30/30 method, and TFTP is not possible as the router does not get assigned an IP address :(
The router doesn't get "assigned" an ip address. the router assigns the address. So if you read through the tftp process, you manually assign an address to your computer. Did you try it?
