AlphaIOmega
Mar 11, 2020Aspirant
Hard reset on Netgear R8000
So my R7000 died last night. Press F to pay respects. I went out to a second hand store and found an X6 R8000 router, but the last user changed the admin password, and Im locked out of changing an...
AlphaIOmega
Mar 12, 2020Aspirant
I have tried the 30/30/30 method, and TFTP is not possible as the router does not get assigned an IP address :(
Mar 12, 2020Guru - Experienced User
AlphaIOmega wrote:I have tried the 30/30/30 method, and TFTP is not possible as the router does not get assigned an IP address :(
The router doesn't get "assigned" an ip address. the router assigns the address. So if you read through the tftp process, you manually assign an address to your computer. Did you try it?
