CD56
Nov 29, 2020Aspirant
Hard wired XBOX one to router and receiving high Ping
I know i have read through the fourms a couple times and done a lot of things that wveryone has said, but here is my ditch effort to try and get some help instead of fixing it myself. I have spec...
Nov 29, 2020Guru - Experienced User
If you direct connect to the modem, what ping times do YOU get? not the tech.
There's also a guide for optimizing settings for DumaOS. have you read through it a bit?
http://support.netduma.com/support/solutions/folders/16000090646
- CD56Nov 29, 2020AspirantPing times are back to normal but then I lose internet to the whole house and wife is mot a happy camper when that happens. I will read through
