CD56
Nov 29, 2020Aspirant
Hard wired XBOX one to router and receiving high Ping
I know i have read through the fourms a couple times and done a lot of things that wveryone has said, but here is my ditch effort to try and get some help instead of fixing it myself. I have spec...
CD56
Ping times are back to normal but then I lose internet to the whole house and wife is mot a happy camper when that happens. I will read through
Nov 29, 2020Guru - Experienced User
the checking the modem is just that, ensuring the modem isn't causing the issues.
What modem is it from spectrum?
- CD56Nov 29, 2020Aspirant
- FURRYe38Nov 29, 2020Guru - Experienced User
What is the mfr and model# of this modem?
I ran through the start up guide again and adjusted all settings Still getting high ping. Also connected to the Modem again and the ping increased to higher than normal. I reset everything thinking that would do the trick but it didnt
- CD56Nov 30, 2020AspirantThought it sent yesterday sorry.
Model: E31U2V1
Make: Spectrum
- FURRYe38Nov 30, 2020Guru - Experienced User
Sounds like the problem is with your ISP service and the modem.
You'll need to work with your ISP and have them help you get this cleaned up.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.You might try a different modem if thats possible with Spectrum.
- CD56Nov 30, 2020AspirantI will look into this and let you know
