CD56
Nov 29, 2020Aspirant
Hard wired XBOX one to router and receiving high Ping
I know i have read through the fourms a couple times and done a lot of things that wveryone has said, but here is my ditch effort to try and get some help instead of fixing it myself. I have spec...
Netduma-Fraser
Dec 01, 2020NetDuma Partner
Just to be clear, when you checked through the modem, are you also checking on the Xbox network settings or somewhere else like speedtest.net?
The ping in the Xbox network settings is just the ping to their authentication/live servers - basically so they can ensure you're paying for Xbox Live. It has no bearing on your actual game ping and based on what you have said that will be much lower. It is likely the Geo-Filter that is blocking a server causing the higher ping reading.
CD56
Dec 01, 2020Aspirant
Yes i checked modem speed test and online tests all those tests are good but xbox is not.
How do i fix that portion with Geo - Filter?
