vrspectre
Aug 01, 2019Apprentice
Hardwire Nighthawk X6 Extender
I just got a new Nighthawk X6 Tri-band WiFi Mesh Extender today. I want to set it up. To extend my wifi network, but I want it to use a wired backhaul to the XR500. Is that possible? I plugged it...
Aug 02, 2019Guru - Experienced User
Please post in the wireless extender forum next time:
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
Glad you got it working. Enjoy. :smileywink:
vrspectre wrote:I just got a new Nighthawk X6 Tri-band WiFi Mesh Extender today. I want to set it up. To extend my wifi network, but I want it to use a wired backhaul to the XR500. Is that possible?
I plugged it in and went through the setup and it seems to be working, but when I go to the admin page I get a note that says "Move your extender closer to your router to improve connection." in big bold on the top which makes me think it's trying to use a wireless backhaul.
Also, when I go to Settings and click Connected Devices on the X6 it takes just sits at Please Wait a Moment spinning wheel and eventually times out. It will work 1 time if I restart the X6, then future attempts to load the page fail.
Also when I view the Device Manager on the XR500, it shows the devices connected to the X6 in the offline section but they do have an IP address. It does now show them connected to either wireless frequency as I would have expected. Is there a way to correct that?
