TealITGyrl
Nov 11, 2025Aspirant
Has anyone figured out how to get Device Mgr to show in the Duma OS XR1000 Nighthawk?
Upgraded firmware from Version: 1.0.0.74 to Current Version of 1.0.1.82_1.0.67 I have rebooted, I've cleared cache, I've switched from Edge, to Firefox, to Chrome. I've tried all 3 in private...
Netduma-Fraser
Nov 14, 2025NetDuma Partner
A factory reset will definitely resolve it
- TealITGyrlNov 14, 2025Aspirant
I've done a factory reset about 4 times this year. Each time the problem returns within a week. I shouldn't have to keep doing a factory reset for this to work. I think it may be time for a new device. I won't touch this DumaOS anymore. It's cool in theory, but there are too many issues. Thanks for the input though.
- FURRYe38Nov 14, 2025Guru - Experienced User
What browser are you using?
How was the FW updated?
- TealITGyrlNov 18, 2025Aspirant
I've tried Edge, Chrome and Firefox (All latest versions, I'm on a Windows 11 system)
From modem, FW was updated manually. Ensuring the proper 1.0.1.82_1.0.67 firmeware was installed.
ISP Modem: TECHNICOLOR CGA4332COM
- Netduma-FraserNov 14, 2025NetDuma Partner
Are you accessing using HTTPS? Most browsers force it now which may be causing it, in which case disabling that for the interface would help. Otherwise if you're using Armor that may cause it as well.
