nSparkz
Jun 19, 2021Aspirant
haserl CGI Error XR1000
Hi I can't log in to my netduma os I get the following error. I also tried using http://192.168.1.1/adv_index.htm to update the firmware it shows no updates... haserl CGI Error ...
nSparkz
I restarted the router with http://192.168.1.1/adv_index.htm now I can't log in with the admin username and password as I normally do in netduma os...
- antinodeJun 19, 2021Guru
> [...] XR1000
https://community.netgear.com/t5/x/bd-p/en-home-nighthawk-pro-gaming-routers
> [...] to update the firmware [...]
From what to what?
> [...] now I can't log in with the admin username and password as I
> normally do in netduma os..."can't" is not a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations. - Netduma-FraserJun 23, 2021NetDuma PartnerWhat happens when you try logging in? Does admin / password work?
