JustRecoil
Jul 28, 2018Tutor
Having Geofiltering Issues
Hi there several games now im trying to use geofilter , now the issue is im having its not showing any sign of ping or connection to peer to peer pings or even server ping this being based on pc game...
Netduma_Jack
Jul 28, 2018NetDuma Partner
Hi there - could you do these steps to fix your problem:
1. Double check you have definitely added your PC to the Geo-Filter. If you have connected both wired and wirelessly to your router on the same PC it can sometimes appear on your Device Manager twice, so it’s possible you accidentally have the offline version added. Simplest way to fix this is to go the Device Manager and rename your online Gaming PC to something unique. Then go back to Geo-Filter and double check that this is the same device you added in the top panel.
2. With the correct device added you need to choose the correct service. For example, Fortnite uses the Unreal Engine. Make sure you are doing this for each game
3. An alternative option is to go to the Device Manager and change your Gaming PC to the device type ‘Xbox One’. Go back to the Geo-filter and remove your PC from the device list and then re add it. It will immediately be added with the ‘Console’ service, which covers all games so everything should appear from now on.
Let us know if you’re still having problems after trying these steps.
JustRecoil
Jul 28, 2018Tutor
