JustRecoil
Jul 28, 2018Tutor
Having Geofiltering Issues
Hi there several games now im trying to use geofilter , now the issue is im having its not showing any sign of ping or connection to peer to peer pings or even server ping this being based on pc game...
JustRecoil
Jul 28, 2018Tutor
Netduma-Fraser
Jul 29, 2018NetDuma Partner
Ensure IP of your device is the same as it is on the Device Manager otherwise you may be adding the wrong one. Once you're sure you've got the right one and have added it then flush the cloud from the Geo-Filters Map settings
- JustRecoilJul 29, 2018Tutor
Yes my ip on the dashboard for my pc is the same as i typed in cmd ipconfig and they read the same
- Netduma-FraserJul 29, 2018NetDuma PartnerFlush the cloud and that should resolve it
