BlakeSF
Nov 16, 2022Aspirant
Having to reboot my XR 500 Daily
Hi, Since 2 weeks i have to reboot my router at least once a day in order to have internet at home, it's becoming very frustrating. I've tried the following things: Turned of qos Factory reset ...
Netduma-Liam
Nov 16, 2022NetDuma Partner
In addition to the above, what's changed in the last two weeks that's led to you noticing this problem? Have their been any changes to your network that you can think of?
- BlakeSFNov 16, 2022AspirantNothing has changed, if anything there was a pc removed from the network and i only have about 5 devices running on it..
Firmware is v2.3.2.134
Duma os is 3.0.202- FURRYe38Nov 16, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Factory reset the router and setup from scratch.
Make sure you change the default DHCP IP address range to 192.168.1.100 to .200
- Netduma-LiamNov 17, 2022NetDuma Partner
Could you please go to Settings -> Setup -> LAN Setup and change the minimum DHCP value to .100.
Then, reserve IPs for each device in the network. Give them IP addresses between . 2 and .99, so they're out of the DHCP range.
See if you still experience crashes after this.
