BlakeSF
Nov 16, 2022Aspirant
Having to reboot my XR 500 Daily
Hi, Since 2 weeks i have to reboot my router at least once a day in order to have internet at home, it's becoming very frustrating. I've tried the following things: Turned of qos Factory reset ...
BlakeSF
Nothing has changed, if anything there was a pc removed from the network and i only have about 5 devices running on it..
Firmware is v2.3.2.134
Duma os is 3.0.202
Duma os is 3.0.202
Nov 16, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Factory reset the router and setup from scratch.
Make sure you change the default DHCP IP address range to 192.168.1.100 to .200
