Kstauffer47
Apr 12, 2023Tutor
Heatmap not pinging for COD
I can ping other games but not Warzone 2.0. Why?
Apr 12, 2023Guru - Experienced User
What model NG router are you referring too?
Please post a screen capture of what your seeing.
What browser are you using?
- Kstauffer47Apr 12, 2023TutorXr500 and I'm using chrome.
- Netduma-FraserApr 13, 2023NetDuma PartnerWe need to update Ping Heatmap, it happens quite regularly that they change the servers used so it needs to be updated. It won't affect your ability to use the Geo-Filter or connect to servers though.
- Kstauffer47Apr 13, 2023TutorThanks for the response
- UnclePepApr 14, 2023AspirantI have same problem
Xr1000
Edge- Netduma-FraserApr 14, 2023NetDuma PartnerAs above, everyone will have the same outcome, we'll get it updated on Monday
- Kstauffer47Apr 14, 2023TutorSounds good 👍
