SunGodxApollo
Sep 08, 2020Aspirant
Help! I am at the mercy of my Modem Nighthawk C7000-100NAS
Constant disconnection issues everyday. Cannot get any work done. I've rebooted numerous time, bought new coax cable, change my service to static ISP, change the MTU to lower numer than 1500, called ...
Sep 08, 2020Guru - Experienced User
t3/t4 errors tend to be signal issues. do you have a screen snip of tthe cable connections page? it shows the values
- SunGodxApolloSep 08, 2020Aspirant
Frequency start Value This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. Starting Frequency Startup Procedure
Procedure Status Comment Acquire Downstream Channel 483000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Security Enabled BPI+ IP Provisioning Mode Honor MDD honorMdd(4) Downstream Bonded Channels
Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked QAM256 5 483000000 Hz -1.4 dBmV 42.6 dB 0 0 2 Locked QAM256 13 543000000 Hz -1.8 dBmV 41.9 dB 0 0 3 Locked QAM256 14 549000000 Hz -1.3 dBmV 42.2 dB 0 0 4 Locked QAM256 15 555000000 Hz -1.1 dBmV 42.3 dB 0 0 5 Locked QAM256 16 561000000 Hz -1.9 dBmV 41.8 dB 0 0 6 Locked QAM256 18 573000000 Hz -2.4 dBmV 41.6 dB 0 0 7 Locked QAM256 19 579000000 Hz -2.9 dBmV 41 dB 0 0 8 Locked QAM256 20 585000000 Hz -2.6 dBmV 41 dB 0 0 9 Locked QAM256 21 591000000 Hz -2.9 dBmV 40.6 dB 0 0 10 Locked QAM256 22 597000000 Hz -2.3 dBmV 41 dB 0 0 11 Locked QAM256 23 603000000 Hz -2 dBmV 41.3 dB 0 0 12 Locked QAM256 24 609000000 Hz -2.2 dBmV 41.2 dB 0 0 13 Locked QAM256 1 459000000 Hz -1.2 dBmV 42.6 dB 0 0 14 Locked QAM256 2 465000000 Hz -1.4 dBmV 42.5 dB 0 0 15 Locked QAM256 3 471000000 Hz -1.3 dBmV 42.7 dB 0 0 16 Locked QAM256 4 477000000 Hz -1 dBmV 42.9 dB 0 0 17 Locked QAM256 6 489000000 Hz -1.3 dBmV 42.5 dB 0 0 18 Locked QAM256 7 495000000 Hz -1.6 dBmV 42.5 dB 0 0 19 Locked QAM256 8 507000000 Hz -0.8 dBmV 43.1 dB 0 0 20 Locked QAM256 9 513000000 Hz -1.4 dBmV 42.6 dB 0 0 21 Locked QAM256 10 519000000 Hz -1.5 dBmV 42.5 dB 0 0 22 Locked QAM256 11 525000000 Hz -2.3 dBmV 41.9 dB 0 0 23 Locked QAM256 12 531000000 Hz -2.7 dBmV 41.9 dB 0 0 24 Locked QAM256 17 567000000 Hz -1.9 dBmV 42.5 dB 0 0 Upstream Bonded Channels (Partial Service)
Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 1 5120 Ksym/sec 30100000 Hz 51.5 dBmV 2 Locked ATDMA 2 5120 Ksym/sec 36500000 Hz 49 dBmV 3 Not Locked Unknown 3 0 Ksym/sec 17300000 Hz 0.0 dBmV 4 Not Locked Unknown 4 0 Ksym/sec 23700000 Hz 0.0 dBmV 5 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 6 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 7 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 8 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV - plemansSep 08, 2020Guru - Experienced User
you only have 2 locked upstreams channels. coupled with your t3t4 errors, did comcast every come out and check the line?
How can I make them Locked? I've spoken to them on the phone and they tested their service and said it was running fine. I've been disconnected at least 15 times this morning. More than usual. Usually is 2-3 times a day.
