Alvarommb
Apr 11, 2019Guide
Help on XR500 PS4 Fifa 19 setup lag (100ms ping)
I need help with my xr500 setup for Fifa 19 on PS4, no matter what I do I always have 100ms ping or above, I have try: upnp on/off DMZ on/off Quos 75%\85%\95% & on/off TP 95%\90%\85% for the PS4 o...
Alvarommb
Apr 11, 2019Guide
I also get disconnected from some matches randomly
- Netduma-FraserApr 11, 2019NetDuma PartnerWhere do you live and what servers are you connecting to?
- AlvarommbApr 11, 2019GuideHi, I live in Peru, and Mostly I get connected to Brazilian servers, but sometimes to mexico’s And US servers also
- Netduma-FraserApr 11, 2019NetDuma PartnerThat is probably to do with it. If you do a speedtest.net test to the closest server when nothing is using the internet what ping do you get?
