Alvarommb
Apr 11, 2019Guide
Help on XR500 PS4 Fifa 19 setup lag (100ms ping)
I need help with my xr500 setup for Fifa 19 on PS4, no matter what I do I always have 100ms ping or above, I have try: upnp on/off DMZ on/off Quos 75%\85%\95% & on/off TP 95%\90%\85% for the PS4 o...
Netduma-Fraser
Apr 11, 2019NetDuma Partner
Where do you live and what servers are you connecting to?
Alvarommb
Apr 11, 2019Guide
Hi, I live in Peru, and Mostly I get connected to Brazilian servers, but sometimes to mexico’s And US servers also
- Netduma-FraserApr 11, 2019NetDuma PartnerThat is probably to do with it. If you do a speedtest.net test to the closest server when nothing is using the internet what ping do you get?
- AlvarommbApr 11, 2019GuideO will try that and post the results
- AlvarommbApr 11, 2019GuideOn the browser of my PS4 I get 25 ms ping to closest server which is my isp server, I’ve try changing my location to Mexico and I still have +100ms ping but the game is much more fluid
- Netduma_JackApr 12, 2019NetDuma Partner
That's quite a high base ping, but I'm happy you are having a better time on the Mexican server. I've seen that before on FIFA - I know a famous FIFA player (Krasi) prefers the Dutch server over the German server as it's smoother for him.
