Alvarommb
Apr 11, 2019Guide
Help on XR500 PS4 Fifa 19 setup lag (100ms ping)
I need help with my xr500 setup for Fifa 19 on PS4, no matter what I do I always have 100ms ping or above, I have try: upnp on/off DMZ on/off Quos 75%\85%\95% & on/off TP 95%\90%\85% for the PS4 o...
Netduma-Fraser
Apr 11, 2019NetDuma Partner
That is probably to do with it. If you do a speedtest.net test to the closest server when nothing is using the internet what ping do you get?
Alvarommb
Apr 11, 2019Guide
O will try that and post the results
