Alvarommb
Apr 11, 2019Guide
Help on XR500 PS4 Fifa 19 setup lag (100ms ping)
I need help with my xr500 setup for Fifa 19 on PS4, no matter what I do I always have 100ms ping or above, I have try: upnp on/off DMZ on/off Quos 75%\85%\95% & on/off TP 95%\90%\85% for the PS4 o...
Netduma_Jack
Apr 12, 2019NetDuma Partner
That's quite a high base ping, but I'm happy you are having a better time on the Mexican server. I've seen that before on FIFA - I know a famous FIFA player (Krasi) prefers the Dutch server over the German server as it's smoother for him.
Alvarommb
Apr 12, 2019Guide
I would try different locations then, do you know if there are some kind of guide/link for the basic setup of the dumaos for PS4? Because I can’t find anything like that
- Netduma_JackApr 15, 2019NetDuma Partner
I'd recommend working your way through these optimal settings guides for each feature you want to configure. Each guide won't take long to follow: http://support.netduma.com/en/support/solutions/folders/16000090646
