zouguanmin
Aug 18, 2021Tutor
Help, the XR700 upgrade version cannot be online
XR700 original version 1.0.1.20 Everything is normal but the upgrade is 1.0.1.38, it is normal but the next day, it is not possible to go to the original 1.0.1.20. It is not possible to brush various...
- Aug 20, 2021omg,router no work again i didn't do anything today in the noon time router no work u can see the picture same yesterday no work
michaelkenward
Aug 19, 2021Guru - Experienced User
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Pro Gaming Routers - NETGEAR Communities
Gaming routers have their own DumaOS operating system that is nothing like the one on Netgear's standard routers.
I will ask the Netgear moderator to move your message.
