zouguanmin
Aug 18, 2021Tutor
Help, the XR700 upgrade version cannot be online
XR700 original version 1.0.1.20 Everything is normal but the upgrade is 1.0.1.38, it is normal but the next day, it is not possible to go to the original 1.0.1.20. It is not possible to brush various...
- Aug 20, 2021omg,router no work again i didn't do anything today in the noon time router no work u can see the picture same yesterday no work
Netduma-Liam
Aug 20, 2021NetDuma Partner
OK, thanks for letting us know, that is strange.
If you run into any other issues please do get back to us and we'd be happy to help.
zouguanmin
Aug 20, 2021Tutor
- michaelkenwardAug 20, 2021Guru - Experienced User
zouguanmin wrote:
omg,router no work again i didn't do anything today in the noon time router no work u can see the picture same yesterday no workI am not surprised.
I meant to suggest earlier that you should answer this question from Netduma-Fraser
Also what is your ISP modem/router?It is a standard debugging question.
That's because the behaviour you experience may be down to the dreaded "two routers" disease.
We can't rule that out without that important bit of extra information.
- Netduma-FraserAug 20, 2021NetDuma Partner
From the picture in your other topic it does say you have an internet connection and you wouldn't be able to get that IP if you didn't. Is it just that place where it says you don't have internet? Can you access websites for example?
- zouguanminAug 20, 2021TutorYes i had an Internet contact but it can't access websites for example is fail
- zouguanminAug 20, 2021TutorU see the machine led is normal
- zouguanminAug 20, 2021Tutorand I can sure my home Internet is fine i use other router is work, xr700 is no work
- Netduma-FraserAug 20, 2021NetDuma PartnerYeah the internet appears fine there. Do any of your devices connected to the router work? On a PC connected to the router open command prompt, type ipconfig and press enter then post the results. Also in the same window type ping 8.8.8.8 -n 10 press enter then post the results.
- zouguanminAug 20, 2021TutorWhen i ping. 8. 8. 8. 8 -n 10 is connection timeout , use other router is reply byte 32 time 12ms ttl 116
- zouguanminAug 20, 2021TutorThis chinese computer the mean is media has been disconnected, i use other rouer is same display
- Netduma-FraserAug 21, 2021NetDuma PartnerUpgrade to the 3.0 beta version, then do a factory reset once it is complete and see if you get the same issue: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/XR700-DumaOS-3-0-Beta-Firmware/td-p/2019958/ if you don't then we'll have some extra things we can try on that version to see whether the router is getting internet but not passing on to devices.
- zouguanminAug 21, 2021TutorIt's work again hope it will continue, sign
- zouguanminAug 21, 2021Tutorif this router tomorrow no work again same last day , what should i do?
- Netduma-FraserAug 21, 2021NetDuma PartnerAre you on the beta version currently? If so can you do a Connection Benchmark test please and provide a screenshot of the results?
- zouguanminAug 21, 2021Tutoris update bate version and router is work now, i mean if tomorrow router no work again same yesterday, what should i do next
- Netduma-FraserAug 22, 2021NetDuma PartnerAhh I see, if it happens again do the Benchmark test as mentioned and post the results please.
- zouguanminAug 22, 2021Tutorthe router is no work again same before what should i do
- Netduma-FraserAug 22, 2021NetDuma PartnerPlease see the above two replies
- michaelkenwardAug 22, 2021Guru - Experienced User
zouguanmin wrote:
the router is no work again same before what should i doNot working or now working?
It always helps to use language that people can understand.Only then can people understand what is going on, and weed out user error from a genuine technical problems.
- zouguanminAug 22, 2021TutorI think it’s not a software problem but a hardware problem. We’ve tried it many times,both work only one day second day is broken
- zouguanminAug 22, 2021TutorBut I really doubt the quality of NETGEAR, since it is broken after upgrading the firmware
- Netduma-FraserAug 22, 2021NetDuma PartnerIf you do the Benchmark test and post the results it will help us determine what exactly the issue could be
- zouguanminAug 22, 2021TutorYeah the internet appears fine there. Do any of your devices connected to the router work? On a PC connected to the router open command prompt, type ipconfig and press enter then post the results. Also in the same window type ping 8.8.8.8 -n 10 press enter then post the results.
u mean this test? - Netduma-FraserAug 22, 2021NetDuma PartnerDo a Connection Benchmark test please and provide a screenshot of the results - you can find it on the interface.
- zouguanminAug 22, 2021TutorNothing coming out
- Netduma-FraserAug 22, 2021NetDuma PartnerThanks, can you grab a copy of the log file on the System Information page please?
