moose1111
Oct 28, 2018Tutor
Help with tweaking my QOS Bufferbloat Ping.
Everthing is set 1000 up and 1000 down from verizon Fios. I do have both slider at 70%. Also I have my Sony TV AND Gaming PC Bandith set to 50 both up and download. Everthing else is set as should be...
Netduma-Fraser
Oct 28, 2018NetDuma Partner
I would not pay attention to DSLReports. Bufferbloat only occurs when your network is saturated. At your speeds and with QoS enabled you will not see this problem. That is not high in the slightest, to give you an idea 5ms is about what you'd get playing on LAN. You have a very good ping, nothing to worry about.
- moose1111Oct 29, 2018Tutor
Thank you Sir
