Rick6922
Jan 13, 2019Luminary
Here we go again
just updated my xr700 to new fireware about an hour ago. will not stay conected to the xbox1x AGAIN.... [UPnP set event: add_nat_rule] from source 192.168.1.8, Sunday, January 13, 2019 13:44:51 [UPnP...
- Jan 14, 2019
i fiqured it out, thanks to all that responed!
Rick6922
[UPnP set event: add_nat_rule] from source 192.168.1.8, Sunday, January 13, 2019 13:44:51 [UPnP set event: del_nat_rule] from source 192.168.1.8, Sunday, January 13, 2019 13:44:48 [DHCP IP: 192.168.1.8][Device Name: XBOXONE] to MAC address 2c:54:91:99:2a:10, Sunday, January 13, 2019 13:44:47 [DumaOS] DHCP lease change., Sunday, January 13, 2019 13:44:47 [DumaOS] DHCP new event., Sunday, January 13, 2019 13:44:47 [DumaOS] config write 'com.netdumasoftware.devicemanager.database', Sunday, January 13, 2019 13:44:47 [DHCP IP: 192.168.1.8][Device Name: XBOXONE] to MAC address 2c:54:91:99:2a:10, Sunday, January 13, 2019 13:44:45 [DumaOS] DHCP lease change., Sunday, January 13, 2019 13:44:45 [DumaOS] DHCP new event., Sunday, January 13, 2019 13:44:45 [LAG] Active lag now, Sunday, January 13, 2019 13:44:42 [DumaOS] config write 'com.netdumasoftware.devicemanager.database', Sunday, January 13, 2019 13:44:32 [Internet connected] IP address: 24.95.165.47, Sunday, January 13, 2019 13:44:20 [Internet disconnected] Sunday, January 13, 2019 13:44:18 is this styem log saying its deleting the nat rule? if so whats that mean?
- Netduma-FraserJan 13, 2019NetDuma PartnerIt's frequently renewing LAN IP address for the device. Set a static IP for the device and also set a static WAN IP for the router itself
- Rick6922Jan 13, 2019Luminary
i just type the ip address into the xbox to do that on the xbox right?
- FURRYe38Jan 13, 2019Guru - Experienced User
No, set a IP address reservation ON the router.
for the static part on the router I dont no how to do.
in the wan setup theres no option for static
