Rick6922
Jan 13, 2019Luminary
Here we go again
just updated my xr700 to new fireware about an hour ago. will not stay conected to the xbox1x AGAIN.... [UPnP set event: add_nat_rule] from source 192.168.1.8, Sunday, January 13, 2019 13:44:51 [UPnP...
- Jan 14, 2019
i fiqured it out, thanks to all that responed!
Jan 13, 2019Guru - Experienced User
Do you have a IP address reservation set for the game console? This is recommended.
Is the console wireless or wired to the router?
Beamforming enabled. Disable MIMO. IF you see Fast Roaming or 802.11k, disable this. Maybe found under router IP/debug.htm
What MFr and model# ISP modem is the XR router connected too?
- Rick6922Jan 13, 2019Luminary
I have the ips reservation . I went through all that the first time. my modem is the NG cm1000. the other things you sugested i dont know how to do.It was working fine till i upgraded to new fireware .
its wired.
- Netduma-FraserJan 13, 2019NetDuma PartnerWAN and LAN reservations? If it occurred when upgrading to the new firmware go back to the old firmware and see if the issue occurs again please. Also disable IPv6 in Advanced Settings.
[DoS Attack: ACK Scan] from source: 199.16.156.58, port 443, Sunday, January 13, 2019 15:36:04 [DoS Attack: ACK Scan] from source: 199.16.156.75, port 443, Sunday, January 13, 2019 15 DO YOU NO WHAT THIS MEANS IN THE SYSTEM LOG?
- FURRYe38Jan 13, 2019Guru - Experienced User
When you did the FW update, did you download the FW file then apply it then continue? Or did you do a factory reset and setup from scratch? You might do a factory reset and set up from scratch.
I would power OFF the modem for 30 seconds then back on, then do the factory reset and setup from scratch.
Don't worry about the suggestions for wireless I meantioned. That would be if the console was wireless connected.
If after doing the reset and setup from scratch doesn't solve this, I would revert back to prior working FW version.
See reply here:
I tryed doing a factory reset , but after the setting ,password dumuOS settings was still there like it didnt reset.
