Rick6922
Jan 13, 2019Luminary
Here we go again
just updated my xr700 to new fireware about an hour ago. will not stay conected to the xbox1x AGAIN.... [UPnP set event: add_nat_rule] from source 192.168.1.8, Sunday, January 13, 2019 13:44:51 [UPnP...
- Jan 14, 2019
i fiqured it out, thanks to all that responed!
Jan 13, 2019Guru - Experienced User
Do you have a IP address reservation set for the game console? This is recommended.
Is the console wireless or wired to the router?
Beamforming enabled. Disable MIMO. IF you see Fast Roaming or 802.11k, disable this. Maybe found under router IP/debug.htm
What MFr and model# ISP modem is the XR router connected too?
Rick6922
I have the ips reservation . I went through all that the first time. my modem is the NG cm1000. the other things you sugested i dont know how to do.It was working fine till i upgraded to new fireware .
