Rick6922
Jan 13, 2019Luminary
Here we go again
just updated my xr700 to new fireware about an hour ago. will not stay conected to the xbox1x AGAIN.... [UPnP set event: add_nat_rule] from source 192.168.1.8, Sunday, January 13, 2019 13:44:51 [UPnP...
- Jan 14, 2019
i fiqured it out, thanks to all that responed!
Jan 13, 2019Guru - Experienced User
Do you have a IP address reservation set for the game console? This is recommended.
Is the console wireless or wired to the router?
Beamforming enabled. Disable MIMO. IF you see Fast Roaming or 802.11k, disable this. Maybe found under router IP/debug.htm
What MFr and model# ISP modem is the XR router connected too?
Rick6922
[DoS Attack: ACK Scan] from source: 199.16.156.58, port 443, Sunday, January 13, 2019 15:36:04 [DoS Attack: ACK Scan] from source: 199.16.156.75, port 443, Sunday, January 13, 2019 15 DO YOU NO WHAT THIS MEANS IN THE SYSTEM LOG?
- FURRYe38Jan 13, 2019Guru - Experienced User
When you did the FW update, did you download the FW file then apply it then continue? Or did you do a factory reset and setup from scratch? You might do a factory reset and set up from scratch.
I would power OFF the modem for 30 seconds then back on, then do the factory reset and setup from scratch.
Don't worry about the suggestions for wireless I meantioned. That would be if the console was wireless connected.
If after doing the reset and setup from scratch doesn't solve this, I would revert back to prior working FW version.
See reply here:
- Rick6922Jan 13, 2019Luminary
I tryed doing a factory reset , but after the setting ,password dumuOS settings was still there like it didnt reset.
Was the reset done with the back button or thru the routers web page? I like using the web page...
Ensure you clear out all browser caches after triggering the reset as well, exit the browser then re-launch it.
Try using IE11, FF or Opera.
