Rick6922
Jan 13, 2019Luminary
Here we go again
just updated my xr700 to new fireware about an hour ago. will not stay conected to the xbox1x AGAIN.... [UPnP set event: add_nat_rule] from source 192.168.1.8, Sunday, January 13, 2019 13:44:51 [UPnP...
- Jan 14, 2019
i fiqured it out, thanks to all that responed!
Rick6922
[DoS Attack: ACK Scan] from source: 199.16.156.58, port 443, Sunday, January 13, 2019 15:36:04 [DoS Attack: ACK Scan] from source: 199.16.156.75, port 443, Sunday, January 13, 2019 15 DO YOU NO WHAT THIS MEANS IN THE SYSTEM LOG?
Jan 13, 2019Guru - Experienced User
When you did the FW update, did you download the FW file then apply it then continue? Or did you do a factory reset and setup from scratch? You might do a factory reset and set up from scratch.
I would power OFF the modem for 30 seconds then back on, then do the factory reset and setup from scratch.
Don't worry about the suggestions for wireless I meantioned. That would be if the console was wireless connected.
If after doing the reset and setup from scratch doesn't solve this, I would revert back to prior working FW version.
See reply here:
- Rick6922Jan 13, 2019Luminary
I tryed doing a factory reset , but after the setting ,password dumuOS settings was still there like it didnt reset.
- FURRYe38Jan 13, 2019Guru - Experienced User
Was the reset done with the back button or thru the routers web page? I like using the web page...
Ensure you clear out all browser caches after triggering the reset as well, exit the browser then re-launch it.
Try using IE11, FF or Opera.
by pushing a pin in the little hole in the back of the router
