Rick6922
Jan 13, 2019Luminary
Here we go again
just updated my xr700 to new fireware about an hour ago. will not stay conected to the xbox1x AGAIN.... [UPnP set event: add_nat_rule] from source 192.168.1.8, Sunday, January 13, 2019 13:44:51 [UPnP...
- Jan 14, 2019
i fiqured it out, thanks to all that responed!
Jan 13, 2019Guru - Experienced User
When you do a reset and setup from scratch, I would also change the default LAN IP address pool to 192.168.1 100 to .150 or .200.
Then set up IP address reservations for your devices and the xbox.
I would also do a hard reset on the game console as well. Hold the power button on the front untill it shuts off. Do a IP address reservation on the router, save changes then reboot. Then power ON the xbox.
- Rick6922Jan 13, 2019Luminary
OMG, did a factory reset and router wouldnt let me back in. finily got in but i had already set ip last # to 250. already did those things, look at the system log........................6 [DumaOS] Marking device that is marked 192.168.1.6 5 2., Sunday, January 13, 2019 17:41:20 [Internet connected] IP address: 24.95.165.47, Sunday, January 13, 2019 17:40:40 [Internet disconnected] Sunday, January 13, 2019 17:40:38 [DumaOS] Marking device that is marked 192.168.1.6 5 2., Sunday, January 13, 2019 17:39:21 [Internet connected] IP address: 24.95.165.47, Sunday, January 13, 2019 17:38:40 [DumaOS] Marking device that is marked 192.
