Rick6922
Jan 13, 2019Luminary
Here we go again
just updated my xr700 to new fireware about an hour ago. will not stay conected to the xbox1x AGAIN.... [UPnP set event: add_nat_rule] from source 192.168.1.8, Sunday, January 13, 2019 13:44:51 [UPnP...
- Jan 14, 2019
i fiqured it out, thanks to all that responed!
rxman4453
Jan 14, 2019Guide
Firmware 1.0.1.2 and 1.0.1.8 are not stable. WAN/Internet drops are prominent. Only workaround that I have found is to just downgrade to 1.0.0.20. It is a stable firmware version.
Rick6922
Jan 14, 2019Luminary
where do I find that FW and how do i install it?
- rxman4453Jan 14, 2019Guide
https://www.netgear.com/support/product/XR700.aspx#Firmware%20Version%201.0.1.8
The previous firmware versions are on this page as well.
- Rick6922Jan 14, 2019Luminary
ok I downloaded that version and went to FW update in setup of router. when i try to install a window opens saying , please select the correct file the file is *.img
