LightningByte
Aug 22, 2019Aspirant
Hidden (already saved) SSID wont show on Windows 10
Hi, Pain in the ass this Netgear, just switched from TP-link thinking I would make an upgrade (stupid paid YouTube ass "revievers", comercial useless crap is what I paid nearly 300 bucks for!!)... Th...
Aug 22, 2019Guru - Experienced User
Looks like this is a MS Windows issue or possible wifi adapter in this PC. The problem is Windows isn't keeping the new currnet settings correctly when it comes out of sleep.
Try a different PC or device to see if it does the same thing.
Something you'll need to contact MS about.
Good Luck.
