Danqna
Oct 28, 2018Follower
HideMyAss VPN client only option
Alternate VPN solution to HideMyAss has been "in development" since February, then we get told in July it's "completed" and sent to Netgear. Is the following a Netgear publication? Look carefully w...
P111
Oct 30, 2018Luminary
In passing I would actually certainly like to say that Netgear made a poor choice with HMA. HMA most certainly do keep records of what you do and they will hand them over to any official body who requests them. You may think you are hidden using HMA but in fact you are not at all. There are good VPN's around but HMA is definitely not one of them.
I guess the use of a VPN is something like WTFast, otherwise why use a gaming router? And yes it is a little odd that Netgear didn't think of this ~ to include gaming in a gaming router... well I call them VPN's but gaming VPN's are not really VPN's rather advanced routing services I suppose. But whatever you call them, they should be in there.
Netduma-Fraser
Oct 30, 2018NetDuma Partner
As you stated you didn't want a response from us I've just sent the topic to a member of the XR500 team instead.
