EQJunky's avatar
EQJunky
Guide
Oct 23, 2019
High bufferbloat reading on download
With QOS enabled my bufferbloat reading on dsl reports is an F with massive ping spikes into the red. I installed the latest firmware. Speedtest on the router is measuring my download speed at 180 down and I have a gig speed download connection. The upload speed seems accurate and the bufferbloat reading on upload is more stable. With QOS disabled the dsl reports bufferbloat score is still a D or F with high ping spikes. I returned my XR500 and got this router but it’s not any better. It’s actually worse. Any suggestions?
  • plemans's avatar
    I'd be looking at my modem if you're tried changing routers and still getting the same issue.
    1. What modem is it?
    2. do you have a picture of your modems connections page?
    3. If you directly connect to the modem and run the bufferbloat test, what results do you get?
    • EQJunky's avatar
      EQJunky
      Guide
      The modem is a netgear cm1000. I just bought it and I wasn’t having this problem with my old router. If I limit the bandwidth in my s8000 switch to 512 down and 32 up my dsl reports bufferbloat scores go to A+ As soon as I turn on any form of QOS on the router my scores go back to F. With the switch completely disconnected my download bufferbloat scores are F.
      • plemans's avatar
        So a couple tests to try.
        CM1000 alone:
        CM1000----R8000:
        CM1000---R8000---S8000:
        Are you using qos of both the router and the switch? limit it to a single device controlling qos.
        Any other monitors being used like traffic monitoring, parental controls, disney circle?
