Killhippie
Apr 12, 2018Prodigy
High cpu useage when logging in And navigating menu
I noticed when you log into the router and your dashboard appears the CPU spikes at about 80% also if you navigate through the menu and then back to the dashboard it does the same. Is that normal? I’...
- Apr 12, 2018I imagine it's just a spike from loading the new page, which isn't an issue really. If it's running super high all the time then maybe a problem.
Netduma-Fraser
Apr 12, 2018NetDuma Partner
