fijal87
Mar 03, 2025Aspirant
High ping
Hello, I've noticed high ping for some time while using the XR1000 router. I ran tests, and the ping is over 20ms. I connected my old router, and the results are normal, with a ping of around 7ms. I...
fijal87
Speed test from devina io
fijal87
- Netduma-FraserMar 03, 2025NetDuma PartnerCongestion isn't active at those percentages, try 70 for download and upload. Do you see that ping increase reflected anywhere else e.g. in a game or just on that test?
- fijal87Mar 03, 2025Aspirant
I changed it to 70%, 55%, but it didn’t reduce the ping in any way—it only made it more stable. Yes, this is reflected in games, with every ping being above 20ms.
- Netduma-FraserMar 04, 2025NetDuma PartnerAre you able to have the ONT handle VLAN instead of the XR?
- fijal87Mar 04, 2025Aspirant
PROBABLY NOT, AT LEAST I TRIED TO LOG IN, BUT IT ENDED IN FAILURE.
- Netduma-FraserMar 04, 2025NetDuma PartnerLogin to your ONT? Did the ISP set it in bridge for you? If so contact them and ask them to set it up how I mentioned
