Alvarommb
Jun 26, 2019Guide
High priority traffic not detected PS4
Hi, My XR500 won’t recognize my gaming console (PS4) as high priority traffic, the red dot doesn’t turn off while playing, I’ve try to put ports manually with no luck (3659 udp/tcp) and then (1-65535 ...
Alvarommb
Jun 26, 2019Guide
Sorry the red dot doesn’t turn ON (not off)
Netduma_Alex
Jun 27, 2019NetDuma Partner
Are you sure you're adding the correct device? Remember that Ethernet and Wifi connections from the same console will appear as two different devices in DumaOS. Find the correct one and name it something unique.
- AlvarommbJun 27, 2019GuideYes, 100% sure that’s the right device
- Netduma-FraserJun 27, 2019NetDuma PartnerDo you have QoS disabled under Anti-Bufferbloats options? If so then it would disable that feature so you need it on.
- AlvarommbJun 27, 2019GuideAt that moment no, but now it’s disable, I get better speed test results when QOS was disable, gonna enable again and test, just to be sure
