ReedB6300
Apr 20, 2022Follower
High upload ping test
why is my ping under load upload ping so high? would this cause me to lag constantly when trying to play online games like call of duty warzone? how can i fix this issue?
Netduma-Liam
Apr 21, 2022NetDuma Partner
Unfortunately I can't see that image yet as it's not been moderated.
A couple of things I'd suggest you do though, first thing is to checkout our optimal settings guide for QoS, linked below.
http://support.netduma.com/support/solutions/articles/16000077073-dumaos-optimal-settings-guide-qos
QoS is the tool you need to reduce your ping under load, it takes control of the network and ensure important traffic does not get held up behind background traffic on your network.
Also, could you just confirm if all devices on your network are connected directly to the XR?
