EST_Nolan
Jul 06, 2021Aspirant
Higher ping after installing XR1000
I recently replaced my old router with a XR1000 to better my PC connection. I mostly play Warzone and would average around a 50 ping with 39 ping being the lowest during low traffic hours. I also have...
Netduma-Fraser
Jul 06, 2021NetDuma Partner
What is the model of the modem the XR is connected to? Where abouts are you located and where are you forcing servers? What does Ping Heatmap show as the lowest ping servers?
EST_Nolan
Not sure what brand the modem is and the the closest server is 32 ping while the highest im forcing is 52. I am in Texas and I’m forcing two servers in Texas and two in Florida because they have the lowest pings
- Netduma-FraserJul 06, 2021NetDuma PartnerDoes the modem have WiFi? Disable Traffic Prioritization on the QoS page, do both consoles get more of a similar ping?
