ahall1993
Jan 19, 2020Aspirant
Higher Ping after XR500 Installation
I have had my XR500 router installed for a little over a month now, and I am still unable to find the right settings to lower my ping. My ISP is Charter Spectrum, and I was getting much better ping ...
Netduma_Alex
Jan 20, 2020NetDuma Partner
First, take a look at the following guides to make sure it's all set up correctly:
QoS: http://support.netduma.com/support/solutions/articles/16000077073-dumaos-optimal-settings-guide-qos
Geo-Filter: http://support.netduma.com/support/solutions/articles/16000077072-dumaos-optimal-settings-guide-geo-filter
With QoS and Geo-Filter set up correctly, you should see a marked improvement to ping.
ahall1993
Jan 20, 2020Aspirant
Hi Alex,
Thanks for the quick response. I have made the adjustments to the settings as stated in both articles you posted, but it doesnt seem to be making much of a difference. Do you have any other suggestions?
- Netduma_AlexJan 21, 2020NetDuma Partner
Sounds like you might need to manually prioritize your device. Add your gaming device to the Traffic Prioritization panel under the Games Console profile.
- ahall1993Jan 21, 2020Aspirant
I have added my device to the traffic prioritization. This did not seem to have much effect on the outcome. I also truned off share excess bandwidth in hopes that it will help. Do you think this might work?
- Netduma-FraserJan 22, 2020NetDuma PartnerAre ALL devices connected to the XR500 router or do you still have some connected to the ISP hub? All devices should be connected to the router so it can control the connection properly. How are you measuring the ping, from the in game reading? What does the ping say on the Geo-Filter?
