jkraft24
Feb 13, 2018Initiate
Higher Ping
After setup I have a higher ping on speedtest and dsl reports... i went from 15ms to 40ms. Did I do something wrong or is this an issue?
- Feb 13, 2018Please download & install TeamViewer: https://www.teamviewer.com/en/download/windows/ once installed open it up and send me via PM the ID & Password it shows you. Then I can connect and take a look.
rogeranthony
Mar 21, 2018Tutor
I have the same problems, higher ping than the old router. Switching to old router's MAC didn't help. resetting router/modem also didn't help. Adjusting things in QoS didn't help either. Tried each setting in anti-bufferbloat. changed bandwidth allocation. Fiddled with traffic prioritization, nothing. Ran the setup wizard twice. Can't seem to fix anything.
- Netduma-FraserMar 21, 2018NetDuma PartnerHi Roger, I assume this is a speed test ping done through a wired PC? What was the ping previously and what is it now?
Are ALL devices connected to the XR500?- rogeranthonyMar 21, 2018Tutor
Everything is connected. There's two smart home devices, iDevices, Roku, ps4, and the PC. PC is wired (modem>router>PC, nothing in between). Everything is recognized as a computer apart from the iDevices and Playstation. Previous router was an old Apple Time Capsule that got a ping in the low 40s. The XR500 is in the low 50s, so 10ms isn't big, but obviously I expect it to perform at least as well as, if not better than, a 7-8 year old Apple Time Capsule. The first time I hooked the device up it didn't setup right thinking I had 1000 down and up and couldn't find a new firmware. Ran updates again and it corrected everything. Thanks for the response.
- Netduma-FraserMar 21, 2018NetDuma PartnerBased on the fact that theres not much difference I expect it's down to ISP congestion, potentially worsened by peak times. If you do a test in non peak times is it as you expect?
