Cjw743
Aug 28, 2022Tutor
Higher ping
When I connect my ps5 straight to my modem I get like 43-44 ping on Fortnite but when I connect my ps5 to the nighthawk xr1000 I get around 50 why is there a difference? I use spectrum and there mode...
Netduma-Fraser
Aug 29, 2022NetDuma Partner
Good advice above, a certain amount will be due to processing the routing to devices, could also be QoS settings or the server you're connecting to. I see you've posted on the Netduma forum as well so I'll post there too.
