Red_Raven
Sep 05, 2019Aspirant
Hilfe zum xr500 info
Hi, ich zieh ende diesen monats um und krieg ein internet mit min. 54 mbits und max. 100 mbits, krieg ein modem/router von der telekom. Ich werde hauptsächlich am PC über Lan zocken und das wlan für ...
- Sep 06, 2019
The XR500 can stop local devices from using a lot of bandwidth but the main limit on bandwidth is always going to be over WAN. Compared to that, your LAN speeds are practically unlimited. So I would say the XR500 is unlikely to make much difference to speeds over LAN.
Red_Raven
Sep 08, 2019Aspirant
ah k thanks
so no xr500 required for 👌 internet
Netduma-Fraser
Sep 08, 2019NetDuma Partner
It isn't required for internet but it would greatly improve the quality and prevent you from lagging when you're playing online!
