Nightfall1293
Nov 15, 2019Aspirant
HMA VPN
So I have HMA vpn and I have it setup and it says connected and everything works great, when I run a leak test on mydesktop after adding my desktop to the devices in the hybrid vpn it comes back as t...
Nightfall1293
Nov 16, 2019Aspirant
Yes and after several tests I've figured out 2 things. 1. I can still easily get the ip using an ip puller and 2. It has a DNS leak, which I am assuming is allowing 1 to happen. The leak also occurs on all other devices like my desktop as well.
Netduma-Fraser
Nov 16, 2019NetDuma Partner
That is something we're aware of and are working on. In the router DNS Settings give it the DNS of the VPN server and that should resolve it in the meantime.
- Nightfall1293Nov 16, 2019AspirantHow would I get the dns of the vpn? And what is that under in the router settings to cha ge the dns is it the internet setup primary and secondary dns?
- Netduma-FraserNov 16, 2019NetDuma PartnerYou would need to contact HMA, they should be able to provide you with that information.
- Nightfall1293Nov 16, 2019AspirantAnd where would I put the dns at? Is it where I said in the previous post? Will I need a secondary as well?
