solifamily
Jul 17, 2020Initiate
Home Networking Setup
I am having a hard time figuring out the best way to connect this with as little interferance as possible. I have a two-story house, about 2600sqft. I have over 40 wifi devices that are connected (...
- Jul 18, 2020That sounds like a good setup as far as I am concerned. Given your circumstances I think that should work quite well for you.
Netduma-Fraser
Jul 18, 2020NetDuma Partner
solifamily
Jul 18, 2020Initiate
Thanks a bunch. I wasn't sure if having the router act as the DCHP server would be good or not. I'll proceed with the setup then and test it out . I'll wait to see if anyone else has any other feed back, otherwise I'll accept your solution . Thanks again!
