SAlhetmi
Aug 15, 2020Tutor
Home Networking Setup
Hi, can someone help me. Right now I'm having orbi mesh network setup which my provider force me to put it , but I'm planning to change it with 2 sx10 switch and xr700 router and ex80 extender. ...
- Aug 16, 2020Thanks a lot for the video, that really cleared it up. I do think you have the right idea with what you want to do. I would suggest having the XR700 upstairs and then connecting your devices to that (with a switch if needed) and the extender downstairs. Then you should have good WiFi coverage on both floors. Your idea will definitely work, might be a case of moving the router/extender around to find what provides the best coverage.
