mach2512
Dec 18, 2018Follower
Hot to Set Up: XR700 with SX10
Hello there,
Wondering if pairing the XR700 with the SX10 will not allow me to use the features of geofiltering and QoS. How can I connect both of them (for the extra LAN ports) wihout los...
Dec 18, 2018Guru - Experienced User
Can the features on the SX10 be disabled, if so, then just connect it to one of the open LAN ports for additional LAN ports where needed. It would be best to use the XR for doing any management needs and let the SX just be a extra LAN port switch.
