juleeanne
Jul 26, 2019Tutor
How can I get netgear, to deregister an original owner, so that I may take his place?
You see, I bought a store return. From amazon. It was practically new - but a much more reasonable 423 (after taxes) , instead of 539 for a brand new one. I had no idea, that the original buyer had al...
juleeanne
Jul 27, 2019Tutor
I assume you're following the instructions here? https://kb.netgear.com/000053098/How-do-I-perform-a-factory-reset-on-my-Nighthawk-Pro-Gaming-router
yes... thankyou for helping. I did do that method, several times actually. Then I went for broke and tried the 30-30-30 method. Neither worked :(
i had the ethernet cable in, for every single attemot described. I was unable to access the routerlogin.net page. I think this guy was super-security oriented. Nothing wrong with that. Its just not helping my super picky box either.. I mean, that reset button IS insane, i know.....but what can i do but ignore the strange crap, & roll with it, when im on a mission to continue to have hope......
Netduma-Fraser
Jul 27, 2019NetDuma Partner
Here is what I suggest, as you can't factory reset for some reason and unable to get the login details this is the best option. Follow this guide, basically it will allow you to upgrade the firmware before the router boots up fully. Hopefully this will then prompt the setup wizard to start so you can bypass it. It's 50/50 as it's not technically a factory reset https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
