Coldimor's avatar
Coldimor
How do I change my 5ghz bandwidth to only be on 40mhz?
I was changing some wifi settings yesterday and did a wifi analyics test from the microsoft store it was saying my 5ghz was at 20mhz bandwidth... I was trying to change channels to one that supported 40mhz but the options are not showing up.
Does anyone know why this would be happening? Basically when I go to select a channel for the 5ghz network none of the 40mhz supported channels are available.
  • FURRYe38's avatar
    Please post about this here for your model router:
    https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
    Good Luck.
    • Coldimor's avatar
      Coldimor
      I tried that only weird thing is that option is only for 2.4ghz the 5ghz that was not an option for.
      I also tried using smart connect and turning off what you suggested and that wasn’t working for me either.
      It’s weird I am only seeing 20mhz channels for 5ghz.
      • FURRYe38's avatar
        There isn't an option for 5Ghz. It's automatic.
        Be sure your 5Ghz devices support 40 or 80Mhz channel width as well.
        Has a reset and setup from scratch been performed?
        What devices do you have that your connecting to the router?
