johndeer11
Mar 18, 2021Follower
How do I change my public ip address on the XR1000
Nighthawk Pro Gaming WiFi 6 Router with DumaOS XR1000 ( AX 5400 )
How do I change my public ip address on this router? I have changed my public IP plenty of times with my old netgear router but this one doesn't seem to have the "change the A to a 0" feature, it's just a numbered ip address that I cant change. I have contacted my ISP and they told me I need to contact the manufacture.
1 Reply
- Netduma-FraserNetDuma PartnerThis is not usually something you can change on a router. The public IP is down to the ISP, unplug your modem for 10 minutes the connect it again and your IP should change.
