P111
Oct 23, 2018Luminary
How Do I Connect To My Modem
One thing that puzzles me, I have a modem sat at 192.168.2.1 and the XR500 router at 192.168.1.1, but for some reason I can't connect to directly to the modem. If I plug the modem directly in to the ...
Netduma-Fraser
Oct 24, 2018NetDuma Partner
How do you usually access the modem interface, is it the IP address? If not can you access by using the IP address?
- P111Oct 24, 2018Luminary
With a browser and I type in 192.168.2.1
If I remove the Netgear that works just fine. With the Netgear inbetween the modem and the PC there is no response from the modem. I would have thought there should be.
- FURRYe38Oct 24, 2018Guru - Experienced User
Have you powered OF the modem and XR router both at the same time for 1 minute, then power ON the modem and let it connect. Then power ON the XR router and let it come to ready. Does the front Internet LED turn WHITE or AMBER? Try walking thru the setup wizard on the XR with a PC and browser.
What Mfr and model# ISP modem do you have?
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the NG router gets from the modem.
Hi there and thank you for the help.
The modem works perfectly, in that I am posting this now using it. It's a Draytek130. The XR500 has no problem with it all and it all works very well. Except for one strange thing ~ DumaOS can see the modem, it displays it in the device map, but I can not actually connect to the modem web page user interface. Normally it resides at 192.168.2.1 and all I have to do is put that IP in and I get the Draytek login screen. Unfortunately with the XR500 the connection just times out - there is no response. I guess at the end of the day it's not that important, but just is slightly odd!
